Type FA fluid
James in CA.
09-19-2005 19:28:24
Anyone know if this tranny fluid is the same as the type A fluid the power steering needs? What was type A used in any way? Ford, GMC?
gerard
09-22-2005 14:58:11
 Re: Type FA fluid in reply to James in CA., 09-19-2005 19:28:24
I"m still trying to figure how a different oil could affect seals. If you look at the compatibility chart of seal materials it doesn"t make sense.
I recall that Borg Warner boxes required Donax T (if I recall correctly) - anyway, there"s 2 types of ATF - one for BW, one for GM & power steerings etc. yet one major manufacturer specified engine oil instead of ATF in auto boxes. Where does that leave us?
I don"t believe the choice of oil is important for seals, but is for gears and bearings (ie oil immersed brakes etc).
james in CA.
09-22-2005 15:54:06
 Re: Type FA fluid in reply to gerard, 09-22-2005 14:58:11
I agree, the oil use to be made with whale oil and they had to reformulate it. I think all these power steering units that had leaking seals were going to leak anyway. The seal material has not changed in the old transmissions and they are doing fine.
Paul in AZ
09-20-2005 09:25:43
James,
MF does NOT recommend using Dextron in any older Ferguson or early MF for either the transmission or as a replacement for Type A fluid in power steering units.
James in CA.
09-20-2005 15:25:49
 Re: Type FA fluid in reply to Paul in AZ, 09-20-2005 09:25:43
Why not? The older cars that required type A fluid all seem to be using dextron without any problems.I'll bet you MF wants me to use there fluid.
Paul in AZ
09-20-2005 20:51:28
 Re: Type FA fluid in reply to James in CA., 09-20-2005 15:25:49
James,
Your question is very timely. In the next issue of Ferguson Furrows I am including an item from Big Dean, a retired MF mechanic. Here is what he says:
Question: My F-40 owner manual calls for Type �A� automatic transmission fluid to be used in the power steering system. However, Type �A� is not longer made. What shall I use?
Answer: MF issued a service bulletin when oil companies switched from Type �A� transmission fluid to Dextron. The bulletin said not to use Dextron in Ferguson or early MF tractors since it was incompatible with the seals that were used in the power steering units of these older tractors. MF said to use MF spec. M1129A or M1127 transmission/hydraulic oil - the same oil used for the hydraulic system in the MF100 series tractors. I have replaced a lot of seals in the older tractors because Dextron had been used in the power steering system.
Any good universal transmission/hydraulic oil meeting these MF specs (M1129A or M1127) will work (such as NAPA 85-401).
James in CA.
09-19-2005 20:52:04
Never mind, after some research I found out A is dextron. dextron is a better formulation
