pto shaft replacement problem/dilemma
guyeli
09-17-2005 15:31:08
I just finished draining all the trans/hydraulic fluid from my TO 30 and removed the old 1 1/8" pto
shaft and assembly and endeavoured to replace it w/a new 1 3/8" pto shaft assembly.As I slid the new shaft in it stopped about 1/4" from being flush w/the housing on the rear of my tractor that receives the four bolts.Thinking I made some silly mistake I pulled it out and re-inserted it only to have it come up short by 1/4" again.I replaced the original shaft and it slid in easily and snugged up flush to the housing.I tried one final time w/the new shaft only to have the same result,I then tried gently tapping the new shaft w/a hamer,but still stuck 1/4" from being flush.My new shaft is a model# 9n700-38 30 7/8" long. from TISCO.The box it came in indicates it should fit 8n 9n 2n to-20 and to-30.HOWEVER IT STILL DOES NOT FIT!!!I compared the two shafts and the new one does have a flange around the bearings that is wider in circumference than the original and thus the problem w/it not fitting flush. Does anyone out there know if I'm doing something wrong or simply need to find a better fitting new shaft assembly????
John (UK)
09-17-2005 16:12:55
 Re: pto shaft replacement problem/dilemma in reply to guyeli, 09-17-2005 15:31:08
No you are not doing anything wrong, you have answered your own question really, there is something wrong with the shaft they have supplied. Take it back and explain, I am sure they will change it. They should fit but it looks as though maybe this one isn't machined correctly from what you say.
