Tachometer for TO 30
guyeli
09-17-2005 12:09:00
Did the TO 30 ever come w/a tach?. Mine is a 1952 and was wondering if it might be compatible to installation of a tach.
Jerry/MT
09-19-2005 21:22:06
 Re: Tachometer for TO 30 in reply to guyeli, 09-17-2005 12:09:00
I bought a 2 inch OD Sun Tach and using a hose clamp attached it to the steering column on my 12 V TO-30. It driven off the coil with a battery connection also and works fine.
Jeff-oh
09-19-2005 05:00:36
Severl people have used a Tach from Norther Tool. It is a digital read and I believe it gets it's input from the electrical system. Thus, you do not need a hook up point for a mechanical cable.
It is Item# 160590
ferguson 30
09-17-2005 19:39:30
You could buy fron the dealer I have one on mine I found it at a tractor show ,it came with a mount that bolts on the right of the steering box on the two bolts down by the choke pull and it is driven by cable off the back of the generator .thay are a little rare
