Dual clutch shaft seal
Richard Friedri
09-13-2005 13:06:57
Work is coming along on my 1955 TO 35. The engine is back together and I made the tools to align the dual clutch. I am now looking at a leak in the bell housing our of the upper shaft area. Can I replace the seals without removing the transmission from the tractor? I have the steering assembly off the top and the PTO bearing housing cover removed as well as the 4 bolts holding the main and PTO shafts. What should I do next? Remove the snap ring on the live PTO shaft (lower) and pull the shaft out forward? Will this unmesh the PTO drive gear and allow me to the retainer housing above? Thanks John and also thanks for the Castro oil update..... ..... ...Richard
james in ca.
09-13-2005 17:38:43
 Re: Dual clutch shaft seal in reply to Richard Friedrich, 09-13-2005 13:06:57
Yes thats how its done, I hope you have a manual. Also when you pull the drive shafts you can use them to align the clutch shafts, did that on mine and the motor went right in.
Richard Friedrich
09-14-2005 16:59:14
 Re: Dual clutch shaft seal in reply to james in ca., 09-13-2005 17:38:43
Thanks James I got it apart today. Hardest part was removing some of the lock rings.I have both manuals but they asume you are removing the transmission. I'll put 3 new bearings in while its apart.Good tip on using the shafts for clutch alignment however I already machined the tool. Richard
