Difference between T0-35 and Delux
Preston
09-10-2005 10:41:22
What"s the difference between a TO-35 (gas) and a Delux?
Ronald in PA
09-11-2005 16:02:29
 Re: Difference between T0-35 and Delux in reply to Preston, 09-10-2005 10:41:22
the delux also has a cushioned seat and the power wheel feature
phil(va)
09-10-2005 19:18:29
There are two TO-35s, the Deluxe and the Special. The Deluxe has a two position clutch, which means you depress it half way and the tractor stops and you depress it all the way and the PTO stops (also known as live PTO). They both have a high-low, six forward, two reverse, tranny. The Deluxe has a tractormeter (proofmeter), but some Specials have that also. Hope that helps.
Richie
09-12-2005 09:08:22
 Difference between T0-35 Special and Deluxe in reply to phil(va), 09-10-2005 19:18:29
Ladies and Gents,
I have read just about everything I can find to help me determine if my TO-35 is a Special or Delux. The answer eludes me still.
My TO-35 (SGF-I72449) was purchased back in the late 60's by my dad. It had been refurb'ed and came with "SPECIAL" decals on the hood, so all of these years I have assumed....
It has the three guages, Tracto-meter, and ID tag on the dash unit and the PTO lever is Marked with Engine-Neutral-Ground, as I have been told these are charitaristic of the DELUXE model.However, when I broke it down to remove the clutch, it only had one disk, typical of the SPECIAL and doesn't look anything like the dual clutch disk pack for the Deluxe. (I had never known this tractor to have ad dual clutch for a live PTO) The parts manual is no help to me, because the casting number on the transmission housing "182 840 MI" doesn't show up in my parts manual ANYWHERE! Can someone help me? Could it be that this is indeed a Delux tractor with the wrong clutch in it or a Special with the guages and two position PTO lever?
Help and Thanks,
Richie
phil(va)
09-14-2005 18:03:53
 Re: Difference between T0-35 Special and Deluxe in reply to Richie, 09-12-2005 09:08:22
The serial prefix of SGF is indicative of a single stage clutch. The Deluxe (live PTO) begins SGM.... I forgot to mention that in my post above.
RegoR
09-13-2005 05:55:35
Hi Richie;
I have a '57 TO-35 Deluxe. It has 4 guages (oil, temp, ammeter & tractormeter), padded seat, power steering and a single-stage clutch although the PTO lever indicates Eng, N and Gnd, like yours. I believe the dual-stage clutch setup on my tractor was either converted or it was built as is from the factory. Either way, it confuses me.
You migh try doing a search on TO-35s in this and the MF forums as there has been lots of discussion over the years on this machine.
Good luck and stay safe,
RogeR
john (UK)
09-12-2005 12:35:56
If it was supposed to have two plates in it there would be two drive shafts into the gearbox, one inside the other. The PTO lever marked like that, they are all alike. The parts number you have will probably be the casting number before machining.
Bill Brox
11-12-2005 02:25:02
 Re: Difference between T0-35 Special and Deluxe in reply to john (UK), 09-12-2005 12:35:56
Right John, and if it had a dual stage clutch and the two shafts, a single stage clutch would not fit. So, in my opinion, if it came from the factory with a dual stage clutch, and now have a single stage clutch, someone have replaced the entire transmission.
But, look to Norway, my MF 35 has the deluxe seat, and the deluxe tractormeter, but the standard single stage clutch. And mine is original, I know that for a fact. But, it was imported to Norway as new, and I assume the company that imported MF to Norway ordered a standard MF 35, but with the extra seat and tractormeter. Or, maybe Massey Ferguson offered that as a special export option.
So, maybe there are some odd tractors around here and there that is no entirely as the book says.
Then, there is one more option, and that is that maybe in 1957 your tractor was a deluxe tractor, but maybe in 1958 it would have had a dual stage clutch too. I see in my TE 20 shop manual that a TED 20, with the kerosene engine, it had 23.9 hp, and the 85 mm standard engine, but everyone says that the first TED 20 had the 80 mm engine that had about 22-23 horsepower
It does not show up in the manual.
Bill
