t o 30 tractor
g l williams
09-04-2005 10:03:38
installed new manifold condensation on intake side of manifold above carb water is cold to touch - never did this before new manifold could they have sent me the wrong manifold tractor wont hardly run- new points, plugs new carb please help
john (UK)
09-04-2005 11:48:14
 Re: t o 30 tractor in reply to g l williams, 09-04-2005 10:03:38
Have you checked the air filter that the correct amount of oil is in there, (up to the line) with engine oil. Have you checked all the manifold gaskets for air leaks. You said in your first post that it ran ok for half-an hour, so according to what you tell us it is something that has happened after that. Did you adjust the carburetter settings? Have you been running it without the air filter connected.
