Light front end... Water in tires?
Just 1 More
09-02-2005 10:36:50
My TO 30 has a very lite front end. When i"m hauling the harrow disc from field to field in the raised position, the front end bounces off the ground and I loose steering at times.. Someone told me to put water in the front tires.. does this sound like a good soultion? Where do I get the fitting to put the water in the front tires? When I had new front tires put on, the rims were getting rusty so I cleaned & duct taped the inside of the rim and then put tubes in the tires.
danct
09-02-2005 11:55:24
 Re: Light front end... Water in tires? in reply to Just 1 More, 09-02-2005 10:36:50
they have weights that fit on the front wheels ,halfmoon shape easy to bolt on and add around 100 pounds to the front end ,maybe just enough for you,if you use water make sure you mix enough antifreeze per side otherwise it will freeze in the winter,if the rims are bad i wouldnt add any fluid only weights ,let us know how you do
Danny
JerryDoyon
09-08-2005 17:56:03
 Re: Light front end... Water in tires? in reply to danct, 09-02-2005 11:55:24
Hey Danct,
I have had the same problem with mine when I use the scrape blade, especially in the winter. (it is a heavy blade) Where could I get some of the front wheel wieght disk?
