condensation on intake manifold
g l williams
09-01-2005 12:29:28
help!!!!! !!!! I installed new manifold that i got from yeasterday tractors. fergie to30- ran good for about 30 min. then started missing out bad. found condesation on intake and top of carb. water was almost cold to the touch. exhaust hot i can not figure this one out help please- tractor died turns over good will not start no water in oil
Jerry/MT
09-01-2005 14:32:04
 Re: condensation on intake manifold in reply to g l williams, 09-01-2005 12:29:28
what awere the ambient air conditions when this happened? Was the humidity very high? During conditions of high humidity, the reduction in pressure in the manifold and carburetor cause the intake air temperatures to reduce and thus water can condense both in the manifold and the carb as well as on the outside surfaces. This is normal.Usualy this will go away once the manifold comes up to operating temperature. If the temperatures are 50 F or less, you can actually have frost form in the carburetor and cause ratty running. Letting the engine run this way for a while allows the intake manifold to warm up and the problem will clear itself. Make sure that your intake manifold gasket AND the carburetor to manifold gasket is seated properly and is well sealed. If you allow any leakage downstream of the carburetor, your cylinder mixture will be too lean and cause poor running and excessively high exhaust temperatures which can burn the exhaust valves.
