Cont Z134 Govenor
Richard Friedri
09-01-2005 05:38:13
Hi I am putting my engine back together and am wondering if you need to index the part of the governor that has the shaft that slides into the camshaft. It covers the ballbearings and has a small square tap which faces the timing cover. I don't want to damage the bumper spring or have to take everything apart. Anyone known about this. 1955 TO35 with Continetal Z134 gas and ballbearing style governor. Thanks..... Richard
john (UK)
09-03-2005 13:56:22
 Re: Cont Z134 Govenor in reply to Richard Friedrich, 09-01-2005 05:38:13
Just put the cover back on, no need to do anything.
john (UK)
09-02-2005 11:50:36
 Re: Cont Z134 Governor in reply to Richard Friedrich, 09-01-2005 05:38:13
If you have had the throttle linkage apart you will need to reset the engine governor linkage. If you need the information, email me at:-
fergusontractors at tiscali dot co dot uk
telling me again what you need.
George in Spokane
09-02-2005 10:44:55
I just did this on the same tractor. If I remember it goes in the 2 o"clock or maybe the 10 o"clock position. The arm on the cover rests on it.
Richard Friedrich
09-02-2005 14:30:21
 Re: Cont Z134 Govenor in reply to George in Spokane, 09-02-2005 10:44:55
Hi John and George, Thanks for the replies. John you were kind enough to send me the setup instructions earlier which I printed and stored. I reread the manual when I was more awake and it states to set the tab at aprox 8 oclock position. Upon further insection of my asembley I elected to replace it with a new one from this site. My ballbearings would not stay captured and the driver was lose on the backing plate. Too much work to remove if bad verses replacing. So tractor waits for parts and 1949 GMC 450 Truck gets some wrench time. Have a Happy..... ..... .....RRF
George in Spokane
09-02-2005 16:40:12
 Re: Cont Z134 Govenor in reply to Richard Friedrich, 09-02-2005 14:30:21
Must be because I'm in a different time zone.
James in CA
09-02-2005 19:44:52
 Re: Cont Z134 Govenor in reply to George in Spokane, 09-02-2005 16:40:12
When you get the governor the instructions will tell you to point an arrow up wich will put it at 2 o"clock, I dont know why.
john (UK)
09-03-2005 13:54:14
 Re: Cont Z134 Governor in reply to James in CA, 09-02-2005 19:44:52
Sometimes the information given with distributors want you to look at the drive from the drive end (upside down) and that will make it 2 o' clock position.
