Gass... I've heard a few guys say it is OK to pull a B. Hog without a top link, but I think you're liv'in dangerous if your do. Under certain, extreme circumstances that top link keeps that Hog from kicking up in the air, wiping out your PTO shaft... and maybe your too. I have a "Thang" also, but never use it for B. hogging. There is a better way. Sounds like you are on the right track. Adjust your B. Hog rear wheel height to your desired cutting height ( sounds like it may not be the right height now?), hook-up your Hog to your TO, without the PTO shaft. Run your TO & hydraulics with the draft control lever all the way forward/down, adjust your top link until your Fergy draft control system just starts to raise the front of your mower deck in response to you cranking on the top link. Now your mower will follow you around at the right height all the time, you can still raise your B.Hog to clear stumps, etc, and drop it right back down to cutting height, no drifting. There have been quite a few posts on this topic in the past that may explain it better than I. You should be able to pull up several using the "search" feature on this web site.Some guys use limiter chains between the tractor top link and the lower links on the B. Hog to hold a set height. I use to do that, but since learning the "right way", my chains have been rusting away in the barn. If, after adjusting your B.Hog this way, your rear wheel is still dig'in ditches, or not following your tractor straight, take a hard look at your rear wheel, the frame may be bent/twisted, wheel shaft bent, or some other problem causing the rear wheel to bind. I run my B.Hog on a lot of horse paths thru woods, lots of tight turns, up & down some fairly steep hills. Don't have wheel digging problems. You should be able to work it out so you don't either.
