overriding clutches
guyeli
08-29-2005 12:22:47
Recently purchased a TO 30 and had the o.r.c. slip
off the pto shaft while bushhogging.I want to replace the o.r.c but,have seen many different types;some have pins through the pto shaft,others
have a spring-loaded pin fastening system.Prices seem to vary from about $29-$100.00.Does anyone recommend a good quality manufacturer that makes one that fits well on the TO 30 1 1/8th shaft?
Jerry/MT
08-29-2005 15:49:27
 Re: overriding clutches in reply to guyeli, 08-29-2005 12:22:47
I just bought one thru Agri Supply that has a spring loaded pin locking system. Haven't got it yet but it seems to be a more convenient way to go. It costs about $45 plus shipping.
gshadel
08-29-2005 13:08:26
guy...
From my personal experience, I'd recommend you get an ORC with the roll pin. It seems like a pain in the butt to install and remove, but once you've done it a few times, you can install or remove in just a minute or two... and it won't fall off on you.
I've been using a ORC that I bought at a T.S.C. back in '99, still holding-up good.
Keep your ORC greased-up real good. Remove it and cap your PTO when using a plow, disc, or other non-powered implement to avoid banging-up your ORC. PTO caps are cheap, a few bucks, the same cap sold for the N works on your TO.
