To35 wheel bearings
jason3101
08-27-2005 07:20:37
I noticed the other day that the front wheels have play when pushing them from side to side.
One is worse then the other.
Can they be adjusted or do they need replacing?
If so where does a man get them?
melam
08-29-2005 10:29:10
 Re: To35 wheel bearings in reply to jason3101, 08-27-2005 07:20:37
They are standard bearings available at most auto parts or bearing distributors and are easily adjusted. These are probably the most ignored parts on a tractor, so I would take this opportunity to clean and repack them rather than just adjust. I just done mine and they were so dry that one had to be replaced. According to the parts book, the only replacement dustcover that MF supplied has a grease zerk in it, so I drilled and put grease zerks in mine too. Takes half a tube of grease to fill each hub, but well worth it.
jason3101
08-29-2005 14:04:20
 Re: To35 wheel bearings in reply to melam, 08-29-2005 10:29:10
Thanks for the information by both guys.
I will check everything as suggested.
john (UK)
08-29-2005 13:06:19
Is the play in the wheel bearings or the steering linkage or even the steering box. Jack the front up and check where the play is first, you may be able to adjust the wheel bearings if they are not too worn, tighten the nut up and then slacken off one castellation and refit the split pin.
