TEA-20 Woes
Cliff
07-06-2000 15:26:13
Where do I start...
I have a TEA-20 that I've owned for about 25 years, the last five of which it's sat idle due to a badly needed engine rebuild. My attempts at getting rebuild parts here in New England for the Standard engine have been less than successful. I've toyed with the idea of finding a Continental Z120 or Z129, and swapping the Standard out, but haven't done anything yet. Is this even feasible?
Are rebuild kits for the Standard engine available in he US? Where? I need sleeves/pistons/rings, main and rod bearings, timing chain & sprockets, plus gaskets, carb kit, and some other goodies before the old girl is right again.
Pete Tatham
07-07-2000 14:06:51
 Re: TEA-20 Woes in reply to Cliff, 07-06-2000 15:26:13
Cliff, All the parts you need are readily available in the U.K. E-Mail me if you have any problems getting them in Canada. Regards, Pete.
Cliff
07-11-2000 18:26:42
 Re: Re: TEA-20 Woes in reply to Pete Tatham, 07-07-2000 14:06:51
Thanks for the reply. It looks as though I might have some options available, but if I run into a dead end, I may take you up on your offer.
Cliff Ducharme
Steve in CA
07-14-2000 15:01:58
 Re: Re: Re: TEA-20 Woes in reply to Cliff, 07-11-2000 18:26:42
How close is the Standard engine to what was used in the passenger cars and the Triumph TR2-4 series? I've heard it's basically the same engine. Perhaps a British Auto parts specialist would have what you need.
stephen cotton
07-25-2000 17:28:45
 Re: Re: Re: Re: TEA-20 Woes in reply to Steve in CA, 07-14-2000 15:01:58
Trimph TR3 uses 87mm liners etc, the TEA uses 80 or 85. Triumph spares are more expensive than tractor spares.
Best of luck
Stephen
