TO35 gear oil
David N H
08-26-2005 11:09:56
I have been putting hydraulic fleid in the fill hole by the shifter and I have trouble with it leaking out of the weap hole on the bottom of the tractor. Looking at the other posting y,all are saying to use 80 or 90 wait gear oil. What should I do??
john (UK)
08-26-2005 12:54:08
 Re: TO35 gear oil in reply to David N H , 08-26-2005 11:09:56
What we say to use is GL1 specification 90 weight gear oil, this isn't the thick oil you use in a gearbox or axle it is about same viscosity as the engine oil. If it is leaking from the drain hole nearest the tractor then most likely the oil seal needs replacing on the main drive into the gearbox. If it isn't too bad you can leave it to a more convenient time, just make sure that the hole doesn't get blocked. Are you certain you haven't overfilled it, check the dipstick on the right side round plate, if you have no dipstick then take out the bottom setscrew and the oil should barely just run out if it is at the correct level. The important thing with the oil is that it must be GL1 90W nothing else will do and it should be changed every 12 months as it goes off like cooking oil.
