TO35 Lift arm / lower bolt asm.
jason3101
08-25-2005 14:24:22
On my tractor when I bought it the bolt on the lower part of the lift arm on the muffler side had been broken. Previous owners drilled a hole in whats left and put a make shift pin in it.
My question, is there a nut inside holding this bolt or is it threaded and inserted from the outside?
john (UK)
08-26-2005 13:07:28
 Re: TO35 Lift arm / lower bolt asm. in reply to jason3101, 08-25-2005 14:24:22
There is a nut on it inside. You can buy a new pin easily though. You have to remove the trumpet housing to replace it.
