engine rebuild
John in B-ton
08-23-2005 08:38:26
I am rebuilding the engine on my TO-20 and have a question.
the expanded drawing in my Ferguson manual shows 2 brass thrust washers on the front of the crankshaft, but when I took it apart there was only one. the rebuild kit included 2 so I assume the drawing is correct, but is it possible I only need 1? the pins that the rear most washer line up on don"t appear to be long enough to engage the holes in the second washer.
this is my first tractor rebuild, though I have rebuilt a number of GM v-8s over the years.
any hints would be appreciated from some of you Ferguson veterans. Thanks
john (UK)
08-25-2005 08:57:51
 Re: engine rebuild in reply to John in B-ton, 08-23-2005 08:38:26
The Ferguson parts list shows only one thrust washer and one plate and 3 pins. It is possible that the kit you have also fits something else as well and that requires the extra thrust washer. While you are doing all this to your engine make sure that the oil pump is in good condition, these engines don't have a lot of oil pressure to start with so any wear on the pump will reduce it even more, now would be a good time to check it while you can easily get at it.
John in B-ton
08-25-2005 09:33:46
 Re: engine rebuild in reply to john (UK), 08-25-2005 08:57:51
John,
thanks for the advice, I was planning on checking it out and the supplier where I got the rebuild kit recommended replacement, and has new oil pumps available, so while it's apart it I'll probably replace it.
gshadel
08-23-2005 14:06:18
John
Far as I have seen, there is only one brass "thrust washer" (manual terminology) with holes in it, for the pins in the block, on TO-20's. There is also a "thrust plate"(manual term again)that goes between the crank gear and the thrust washer. That thrust plate doesn't have holes in it, but probably has a keyway cut in it where it slides down the keyed crankshaft.
The TO-20 has flanged front main bearing shells, the TO-30 does not have flanged bearing shells, but has another thrust washer that goes up against the #1 bearing shell.
It might be possible your kit also included the thrust washer for the TO-30 #1 bearing.
Hopefully you pulled out some thin steel shims when you pulled your crank. You may need them to adjust you end play when you re-install your crankshaft.
John in B-ton
08-23-2005 14:32:19
 Re: engine rebuild in reply to gshadel, 08-23-2005 14:06:18
Thanks for the response, yes I did keep the shims, though I haven't adjusted end play with shims before, are there any easy tricks aside from the directions in the manual?
