TO-20 outer seal
Mark4
08-21-2005 18:52:21
I am replacing the brakes on my TO-20 because oil leaking. I am really torn if I should split the ring and replace the outer seal or just do the sure seals. I would prefer to just do the sure seals but am wondering what will stop the grease from finding its way out past the already leaking old seal? Thanks in advance
john (UK)
08-23-2005 05:44:43
 Re: TO-20 outer seal in reply to Mark4, 08-21-2005 18:52:21
If the bearing is ok then no real need to split the hub off, just use sure seals. The grease will not go past the original seal unless the bearing was really worn and it couldn't seal properly. It was oil that causes the problem and Sure Seals stop all that.
Jeff-oh
08-22-2005 13:11:41
Many have reported the sur seals work fine and have had no problems after many years.
gshadel
08-22-2005 13:49:06
 Re: TO-20 outer seal in reply to Jeff-oh, 08-22-2005 13:11:41
I'm glad to hear that, I bought sur seals off Ebay a few months ago... One of these days, I'll get them installed... I've been dreading pulling my filled tires, still thinking about it. Might have to get a 6 pack and invite the neighbor over.
Mike G. in NB, Canada
08-23-2005 09:02:56
 Re: TO-20 outer seal in reply to gshadel, 08-22-2005 13:49:06
If you're working in a building, you might want to loop a chain through the wheel and over an overhead beam. This will keep the wheel from falling over and damaging you.
I've seen it done this way; you can "walk" the wheel sideways out of the way.
Paul in Ms
08-23-2005 04:27:45
Through the years I have replaced the outerseals twice with no luck. Installed sure-seal 3 years ago and still no oil on brakes.
Myrl
08-23-2005 04:37:47
 Re: TO-20 outer seal in reply to Paul in Ms, 08-23-2005 04:27:45
Where can i get these seals?
john (UK)
08-25-2005 09:04:56
 Re: TO-20 outer seal in reply to Myrl, 08-23-2005 04:37:47
Try a Ford dealer I think they use them on the 9N some of the Ferguson dealers have them too.
