hydraulic arm leaking
dan from bright
08-20-2005 07:06:22
one of my hydraulic arms leaks fluid is this something i can repair or do i take it off and take it somewhere
John (UK)
08-20-2005 08:28:28
 Re: hydraulic arm leaking in reply to dan from brighton, 08-20-2005 07:06:22
You don't say what tractor you have. By hydraulic arm do you mean one of the lower link arms? if this is what you mean you can repair it but it depends on how long it has been leaking and how loose it is as to what you have to do to repair it.
John (UK)
08-21-2005 07:07:52
 Re: hydraulic arm leaking in reply to John (UK), 08-20-2005 08:28:28
Aaah! you mean a hydraulic ram that is leaking ok.
well you may be able to repair it depending on how bad it is, perhaps you could try looking for a hydraulic ram specialist in your area who may be able to help if you think the job is too much for you. You don't say what the loader is so we cant say about availability of parts or difficulty in repairing it.
dan from brighton
08-21-2005 13:55:53
 Re: hydraulic arm leaking in reply to John (UK), 08-21-2005 07:07:52
its the arm for my front end loader which has a bucket on it and it appears that the little ring keeps popping out and leaking
John (UK)
08-21-2005 14:20:16
 Re: hydraulic arm leaking in reply to dan from brighton, 08-21-2005 13:55:53
Its the bucket ram then, still don't know what make. If that is all the problem is that the circlip pops out it will be because the groove is worn, it will be possible to stop it coming out either by re-cutting the groove or maybe depending on how bad it is, using some weld spots above the groove to stop it coming out
dan from brighton
08-24-2005 17:39:30
 Re: hydraulic arm leaking in reply to John (UK), 08-21-2005 14:20:16
yes, john that ring keeps popping out and leaking, so how can i fix that
john (UK)
08-25-2005 08:22:12
 Re: hydraulic arm leaking in reply to dan from brighton, 08-24-2005 17:39:30
Only possibly by doing as I suggested in that email. Have the groove re-cut or some spots of weld above the circlip groove to prevent the circlip slipping out, that is very crude but sometimes you have to resort to things like that as it may be the only way to do it. You could look around you area for some hydraulic ram repairer in Yellow pages, maybe they can do something for it.
dan from brighton
08-21-2005 06:27:32
the tractor is a ferguson tea and the arm leaking is to lift the front bucket
