can't lower lift arms on TO35
Jason3101
08-17-2005 20:50:36
I started my tractor the other day and raised my brush hog implement and it raised all the way to the top and I can"t lower it until tractor is shut off.
Also I"m not sure what the draft controls do not being that familure with tractors.
Any help would be great.
Jason3101
08-20-2005 20:00:35
 Re: can't lower lift arms on TO35 in reply to Jason3101, 08-17-2005 20:50:36
John, I found the valve to be stuck on the pump.
I moved it back and fourth and it seems to work great now.
As I"m reading other peoples troubles as suggested I will change the fluid as possible contamination could be a factor.
Thanks for the help
Jason
John (UK)
08-21-2005 14:23:44
 Re: can't lower lift arms on TO35 in reply to Jason3101, 08-20-2005 20:00:35
That is very often the problem, make sure to use the correct grade of oil and drain it when it is hot so it will all run out. GL1 90 weight 28 US quarts
John (UK)
08-18-2005 12:49:36
Not being familiar with the controls is most likely your problem, if not that it will be the control valve has stuck. If you email me at :-
fergusontractors at tiscali dot co dot uk
and ask me for the operating instructions for the hydraulics on a TO35, I will send the information to you. You can then see what if anything you are doing wrong and if it is the Control Valve I can also send instructions for freeing that too.
