TO-30 Clutch pedal tension... ???????
Just 1 More
08-16-2005 16:21:21
How much tension should be on the clutch pedal at rest? Should there be any at all? Should there be a little play in the pedal before it engages the clutch or should there be pressure on it holding the pedal up tight against the stop??
John (UK)
08-18-2005 13:08:48
 Re: TO-30 Clutch pedal tension... ??????? in reply to Just 1 More, 08-16-2005 16:21:21
The free play on the clutch pedal should be 3/8" under the footrest NOT 3/16" which is a misprint in the manual (on the drawing it quotes 3/8" and in the splurge it says 3/16" but the Genuine Factory Service Manual says 3/8") 3/16" is too small to allow for vibrations and heat build up it will cause the bearing to run if it gets too warm.
Jerry/MT
08-16-2005 18:05:23
The shop manual calls for 3/16" free play in the pedal as mesured between the pedal and the radius arm end housing.
Just 1 More
08-16-2005 19:06:52
 Re: TO-30 Clutch pedal tension... ??????? in reply to Jerry/MT, 08-16-2005 18:05:23
Thanks Jerry
