TO30 Rebuild
Greg Indy
08-15-2005 15:19:33
Just pulled the engine to fix a cracked block. Is there anything in the front end of the transmission or anything else i should look at while this is split open. Haven't had any problems but do you guys do any general maintainance at this time while the engine is out of the way? Thanks for helping us rookies
Jerry/MT
08-15-2005 20:58:46
 Re: TO30 Rebuild in reply to Greg Indy, 08-15-2005 15:19:33
I'd check the clutch, pressure plate, and throwout bearing as well as the transmission input shaft seal. If there is any sign of leakage around the input shaft seal, replace it.
Greg Indy
08-23-2005 14:45:18
 Re: TO30 Rebuild in reply to Jerry/MT, 08-15-2005 20:58:46
How hard of a job is this? Any special tools needed? Thanks for your help.
