TO-20 sediment bowl vapor locks when tight why???
Tom
07-03-2000 06:30:08
My TO-20 started only running when the sediment boyl was left loose enough to slightly drip. What is going on here? I am fairly sure it has something to do with the rubber gasket. Where does the strainer vent and how does the rubber gasket figure in. My Farmall is acting the same way too so this is starting to suck. What am I missing on positioning the gasket or whatever??? Thanx
SandyB@TN
07-03-2000 18:33:46
 Re: TO-20 sediment bowl vapor locks when tight why??? in reply to Tom, 07-03-2000 06:30:08
Tom,
This shouldn't be. Check your gas cap to make sure it's vented. Sometimes the valve in the cap sticks and doesn't allow air to enter the tank. This will definitely shut you down. If air can't get into the tank, gas won't flow to the carburetor. In loosening the the gas bulb, it sounds like you're venting the tank there.
Sandy
