New Leak
RogerL
08-06-2005 23:54:13
Well, the PTO seal no longer leaks, but I get s slow drip from the weep hole under the bellhousing, next to the front drain plug on my TO-35. It's hydraulic fluid, and it only weeps when the tractor is running. Any ideas? I'm going to live with it unless it becomes very serious, as I don't have time or facilities to split the tractor at the moment.
John (UK)
08-07-2005 05:49:40
 Re: New Leak in reply to RogerL, 08-06-2005 23:54:13
Just make sure to keep the holes clear and clean and it will be fine until you get the time to do it.
Little Dave
08-07-2005 01:36:15
Transmission input shaft seal and/or gaskets. I had to replace mine on a TO-30. Dave
