sparks and sputters
Jake H
08-01-2005 10:11:07
my "55 TO-35 used to run just fine, it would fire up every time you hit the starter switch. but now when i try to start it all i get is a spark from the positive terminal on my battery(12 volt neg ground system). also, the coil gets very hot from just trying to start it. does that mean i need a new coil? i only hope its something so simple.
Thanks
Jake H
gshadel
08-03-2005 05:44:15
 Re: sparks and sputters in reply to Jake H, 08-01-2005 10:11:07
the spark at the battery post just sounds like dirty/loose connection. Clean and tighten, should be OK.
Sounds like your coil is probably shot. You can check resistance across the primary wiring (12V), I think a 12V coil should be ~3 ohms, a 6V coil should be ~ 1.5 ohms. If it is much less than that it is shorted out inside the coil. Jerry raises some good questions. You need either a 12V coil, or a 6V coil with a ballast resistor. At this point I'd recommend just getting a new 12V coil (cheap).
George
Jerry/MT
08-02-2005 15:20:13
Do you have a 12 volt system using an alternator? Do you have a regular 12 Volt coil or are you using the original 6 V coil? If you're using a 6V coil on a 12V sysytem, you need a ballst resistor in the coil circuit to limit the current otherwise it will overheat the coil and cause it to fail. NAPA has a 12 volt coil for about $15 that you can install if your old coil is shot.
