Need help with PTO shaft
Michael U
07-31-2005 18:39:03
I own a '52 TO-30. Last week I was bushhogging, and I got a little too close to the ground. I noticed the PTO shaft lever had jumped out of gear. This has never happened before. I re-engaged the PTO, went forward a little more, and noticed the bushhog wasn't working. I looked down at the PTO shaft and noticed it pulled out of the tractor about 2-3 inches and was leaking oil. I unhooked the bushhog and re-engaged the PTO. It would still spin. While it was spinning, I tapped on the end of it with a sledgehammer. PTO shaft slid back into the tractor and worked fine. I need help. What's wrong? I replaced the PTO shaft last year and have had no problems until now. I'm about to sell the tractor out of frustration.
Mark Kothe
08-01-2005 06:39:58
 Re: Need help with PTO shaft in reply to Michael U, 07-31-2005 18:39:03
third party image
If the TO30 shaft is the same as the TO20 that I have, the only way I see for the shaft to "walk out" is for the large snap ring that retains the bearing (#4) to be missing, or out of it's groove. This would allow the whole shaft and bearing to move outward. There is / should be a step in the shaft that stops it from coming out with out the bearing. See picture above.
Mark
