MF 35 starter problem
Scott
06-28-2000 19:41:53
Hi guys
I have a petrol Mf 35. This morning on trying to start her up the solenoid made a loud clicking noise and nothing would happen. The starter motor spins freely still. Before this i have been having some problems with the starter motor making a loud grinding noise and only turning the motor over slowly, also the starter motor sometimes would spin round byt not engage and crank over the motor. The starter is a 12v Lucas M35G.
Any ideas on why this is happening?
Thanks a lot
Scott
phil
06-29-2000 13:05:35
 Re: MF 35 starter problem in reply to Scott, 06-28-2000 19:41:53
Jump it from another battery on running tractor or car (if 12 V) and if it starts good that way, it is probably the battery. Check cables however; They can cause problem. If it does same thing, have starter rebuilt. If armature ok, and drive gear ok, probably $45 to rebuild. Max price if really bad around $115 in my neck of woods.
Roger
06-29-2000 12:13:12
If it turns out to be a bad starter, have it rebuilt- it's only a fraction of what a new one would cost.
Chip
06-29-2000 09:02:34
I would check the battery first, usually just needs a charge. Otherwise, sounds like the solenoid needs looking into.
