Low oil pressure
Paul
06-28-2000 18:36:26
I have a Fergusen tractor am concerned with its oil pressure. What is normal or minimal pressure?
Doug
08-08-2000 14:32:43
 Re: low oil pressure in reply to Paul, 06-28-2000 18:36:26
I ran my TO-35 for 5 years with low pressure (10)until it scored the cylinders. Turns out that the gears on the oil pump had worn and weren't turning out enough pressure. Turned a smaller mechanic job to a major one.
TO2033322
06-28-2000 20:56:06
Paul according to the I&T book pressure should not be below 15 psi @ idle. pressure should be 20 to 30psi @ 2200 r.p.m. Hope this helps.
Bill Mc
Mike
06-29-2000 18:54:48
 Re: Re: low oil pressure in reply to TO2033322, 06-28-2000 20:56:06
I just yesterday finished a 3 day drive in Iowa with my TO 20. I had installed a new gauge before the trip. I had not touched the engine internals and I also do not know how many hours are on the engine. That being said, I had 20 lbs at idle and stayed at 30 to 35 lbs while at speed. I use 10w 40. Those numbers agree with the book. Mike
