Runs and stops
chasbo
06-27-2000 17:09:08
My Ferguson model TEA262071 has a Zenith carburator. It will start fine, yet only runs for about five to ten seconds and stalls out. It will restart immediately. I have cleaned the inside of the carb, jets, float and chamber, blownout the fuel lines and played with the needle valve settings. I have a good gas flow ( not excesseve ) when I open the lower drain valve. I have tighened all screws and bolts on the carb. whats left? Has anyone had a simular problem? thanks for any suggestion.
johnny green
07-16-2000 21:24:21
 Re: runs and stops in reply to chasbo, 06-27-2000 17:09:08
my to 20 had a bad sediment bowl and vave assy. they cost less than 20 bucks a lot better than 160 for late style carb. please dont ask how i know that. the ol part bird dog
Don
07-03-2000 12:48:48
If Petrol / TVO, the fuel tap may need a new washer as it maybe leaking TVO into the fuel supply when cold. Also check filter bowl gauze.
Joe Ferguson
06-30-2000 21:20:18
Hi Chasbo
Take a recipient, open and remove the little "T" chaped drain valve at the bottom of the Zenith carburator, gas should flow continuously if not
unscrew the pipe fitting at the carburator the gas should flow continuously if not check back
all components to the fuel tank. If flows at the
pipe fitting and not by the carb drain valve
may be the pointer needle orifice is blocked with dirt or the float does not operate properly.
My Zenith carburator float chamber was deformed
by standing water freezing in the float chamber
or was hitted by something or by the previous owner. If you want to see if the float operates
correctly when the carburator is disassembled
put the float gently in the chamber it supposed to
go to the bottom of chamber with no restriction,
after that fill the chamber slowly with water
the float supposed to go up freely.
Mine did not operate freely because the chamber was oval, I did'nt take the risk to brake the
chamber wall by binding, I just milled the inside
slightly just as enough to permit the float to
operate freely.
By the.. way check if the float is not upside down, top is indicated on it.
Hope this help
Joe Ferguson
TO2033322
06-28-2000 20:37:54
Hi chasbo a guy on the n board had the same problem. His tractor had an in-line fuel filter that was new but would not gravity flow enough fuel to keep it running more that 20 seconds at a time. Sounds like a fuel problem to me .Good Luck!!
Bill Mc
rod
06-27-2000 18:09:57
Well did you take off sediment bowl and check for dirt in the small passages in the top where it goes in the tank? Also your condenser may be bad points and coil check too. Dirty points are common especially if tractor sits a while they will turn green and corrode. What about air leak form carb to intake? Also the key switch can be defective Just a few things to check. PS new points and condenser fixed my TEA 20
regards
rod
