Well, that wasn't fun
holcombwa
07-17-2005 22:13:10
Ok, I may be missing something, but finally gave up on the TEA20 and hooked the mower back on the Case VAO with 3 1/4 cylinders. (tommorrow may try the troy-bilt walk behind with 30 inch sickle.) Field was mostly 3ft. high lotus (birdsfoot trefoil) but with native species and weeds too. Lots of deer and elk trails/beds and lots of places where it has been beated down by the incessant rain. The JD #9 sickle bar just had a heck of a time with it (and yes the sickle is indexed, tuned, sharpened, lubed, aligned, angled, adjusted, anointed with holy water and everything else that could possibly be done with it to make the darn thing cut.) Is just really tough cutting. Putting the fergy in reverse and backing up to clear the jambs, then going again mowing..... well, that just doesn't work in this stuff. Having the PTO on to use the hydralics was a REAL drawback. Like I said on the top, might be missing something. But, at this point it is dark, I'm beat, and only have our smallest field mowed. The Fergy is a cool little tractor, but right now don't know what role it would fill for us.
Stan
steveormary
07-18-2005 17:24:28
 Re: Well, that wasn't fun in reply to holcombwa, 07-17-2005 22:13:10
Something must not be right there. Are the guards in good shape? What gear are you using? If you run your engine over half throttle you will be operating your mower too fast. Do you have a 9"or7" cutter bar. We used 3pth mowers with our Fergusons and Fords. We never had any serious problems mowing. None had lpto or live hydraulics.
Anyway,good luck and be careful.
steveormary
gerard
07-18-2005 15:21:11
Horses for courses - there"s times when higher spec kit makes life a whole lot easier. Live hydraulics, two stage clutches, position control etc weren"t invented for fun, but to fulfil a need.
Chopper2
07-19-2005 04:29:32
 Re: Well, that wasn't fun in reply to gerard, 07-18-2005 15:21:11
Would you like to try my JD mower? I have had all the same good luck with mine as you have with yours:)
The Fergie is the best, I mean the best on a ground drive side delivery rake. Set your draw bar out to give you the shortest turning radius, hook her up, put her in third gear, and do the neatest raking job in the county.
Good luck with the hay, we have a poor crop this year, so far.
holcombwa
07-19-2005 21:22:41
 Re: Well, that wasn't fun in reply to Chopper2, 07-19-2005 04:29:32
Glad I'm not the only one struggling with the old mowers. Embarassed to say, mine is only a 6' and still has a hard time. Nasty stuff this.. trying to mow it about a month too late.
Stan
