low power rear three points
Huggybear
07-17-2005 19:53:18
I need some help on where to check fo low oil or hydraulic fluid for the rear pump on a T030 Ferguson I have it but i dont know much about it So I am A dummie Thats my other problem
John (UK)
07-18-2005 12:08:33
 Re: low power rear three points in reply to Huggybear, 07-17-2005 19:53:18
The oil in there is to GL-1 specification which is 90W you can buy it at NAPA cheaper than anywhere so the guys on here say.
Jerry/MT
07-17-2005 21:27:13
By "...rear pump...", I presume you mean the internal hydraulic pump the moves the three point hitch. On the right hand side below the seat on the transmission case there should be a dip stick for the trans/hydraulic fluid. It's in the middle of a circular cover plate. If it's missing, the fluid level is OK if, when you remove the lowest bolt in the circular cover plate, the fluid leaks out. You need to get yourself a Ferguson Shop Manual, Parts Manual and Owners Manual. They have all the spec's and system info that you need to understand how your TO-30 works, how to use it and how to fix it.
