Running Temperature
Jake H
07-16-2005 15:35:56
what is the normal running temperature on my TO-35? somewhere around 190-205? i was wondering because the thermostat doesn"t open until 180.
Thanks
Jake H
p.s.- my uncle just got a brand new 59 horse-power JD 4520...front end loader and backhoe...its awesome...but i still think i got him beat with the almighty FERGY!! ...lol...maybe not...
Cosmo
07-17-2005 04:01:44
 Re: Running Temperature in reply to Jake H, 07-16-2005 15:35:56
Jake, I have a 180 degree thermostat and it allows the temp to rise to about 195-200 before opening at initial warm up. Once the coolant starts flowing it holds a constant 180. (Unless the screen in front of the radiator is covered in leaves and other crap from brush hogging.)HTH. Regards, Cosmo
Jerry/MT
07-16-2005 16:39:28
The opening point on a thermostat is set to keep the engine temperature at an optimum point for fuel economy and wear. The thermostat will hold that temperature by increasing the thermostat's flow area as long as there is sufficent cooling capability from the radiator. If the radiator cannot provide any more cooling capability then the thermostat's flow area reaches it's maximum and the temperature of the coolant rises. Just before the boiling point is reached (which is determined by the type of collant and the pressure in the cooling system), the temperature gauge should be in the red zone.
