Will a 9N muffler fit a TEA20?
Rod in Smiths F
07-15-2005 14:15:30
2440044
Princess Auto has this item on sale for 20 dollars, what seems to be a complete exhaust system. It is listed as for the N series Fords. Will it fit a Fergie?
tractorfix
07-16-2005 04:59:54
 Re: Will a 9N muffler fit a TEA20? in reply to Rod in Smiths Falls, ON, , 07-15-2005 14:15:30
Ford exhaust will fit US uilt TO's. It will not fit english TEA's. If you can weld or braze, you can simply swap the Fergy specific flange onto the N exhaust and be done. I have done this before . Better yet, adapt an elbow and change to vertical. I used a MF35 elbow.
Roughstock
07-15-2005 20:21:44
Look at were the exsaust pipe connects to the manifold. If the old one has the bevelled edge like the n tractor then yes it will fit. I just took one off a 8N and put it on the TO30. If yours reqires the 3 bolt then no it won"t fit.
Ray,IN
07-15-2005 22:34:54
 Re: Will a 9N muffler fit a TEA20? in reply to Roughstock, 07-15-2005 20:21:44
There is one small difference I know of. Both have the flanged connection to mate with the exhaust manifold, about 4-5" below the flange the Harry Ferguson exhaust pipe/muffler(all one piece) has a slight bend in the pipe to better clear the engine; the Ford pipe does not. When you buy a new flanged pipe, go ahead and buy a new clamp to hold the manifold pipe to the manifold. They rust and the exhaust heat + vibration erodes the clamp to the point it will not hold securely.
