What is to hot / overheat temp on a 55 to35
joel kercher
07-14-2005 10:10:33
I just finished having my radiator recored, thermostat replaced and a new gauge. It goes up to 170 range after idling for 1/2 hour. I haven"t started bush hogging and want to make sure I don"t go to hot. I can"t seem to find anything that says 200 is to hot or 220 is when you should stop and let the tractor cool down. Any help would be greatly appreciated.
Az John
07-16-2005 05:41:58
 Re: What is to hot / overheat temp on a 55 to35 in reply to joel kercher, 07-14-2005 10:10:33
I noticed on this website the temp of the termostate for sale is 160. Is this too cool? Is it possible and if so where can a person put on an aftermarket temp gauge?
buickanddeereg
07-15-2005 17:10:18
Engines run cleaner, more efficient and last longer at 200F instead of 170F. Never mix your antifreeze with tap water. Tap water is just about a saturated solution of calcuim,lime etc. Ever wonder where all that white scale comes from that is plugging up the rad? You poured it in there yourself. Learned that one the hard way.
etshobby
07-15-2005 07:33:17
The radiator job is great but one other thing I have found in rebuilding and changing cyclinder sleeves is the amount of build up of rust and gunk between block and cyclinder walls you will be surprised . I just hope you flushed block a lot best thing you could have done most times a problem is not only the radiator but the acccumlamation of gunk creating a hot spot which can and has damaged many a cyclinder wall worst heat increase is after using heavy and then shutting down heat will increase in these areas and cool down last.Watch your anti freeze if used in your area many are just poured in and the lable never read some can and should have water added to straight can make it gummy in time in the block or radiator. Dont forget too flush at least once a year. To your other part of question look at your radiator cap for pressure and look at thermostat temp. these control also heat and blow off if no air is allowed in system should not boil over dont over fill.
JOEL KERCHER
07-15-2005 10:51:42
 Re: What is to hot / overheat temp on a 55 to35 in reply to etshobby, 07-15-2005 07:33:17
I ran radiator flush thru the old one last year. I put the recored back in, dumped 1 gal water, 1 gal antifreeze, replaced the cap is says 10psi on it and also replaced the thermostat. next year I will drain and run a garden hose thru. I don't really want to tear back down.
etshobby
07-18-2005 15:13:07
 Re: What is to hot / overheat temp on a 55 to35 in reply to JOEL KERCHER, 07-15-2005 10:51:42
any time there is soft plug get new ones first on hand sometimes if really a problem I have removed them and dug the junk out then washed really good all around . Take a small 1/4 inch or so hose adapt to garden hose you dont need a lot of pressure just a good volume of water and run in and around hose just keep proding and flushing the cleaners help but the best is a coat hanger, water and patients.
Eric Stevens
07-14-2005 19:31:30
Gentleman, remember also that the higher the pressure is on your radiator cap, the more heat it will take to boil. That is why it leaps out when you pop the cap. Rapid release in pressure of course decreases the vapor pressure allowing the liquid to rapidly boil. Antifreeze alone may list info. on the back giving boiling points at different densities and pressures. It may not though. We'll have to check. My belief is that you get nearer to 260F you are going to do damage. My 2 cents
tennesseefarmer
07-14-2005 11:03:45
Your engine temp will go up to the rated temperature of the thermostat. In other words if you have a thermostat rated at 170 degrees the coolant temp will get to that point before the thermostat even opens allowing coolant to circulate between the engine, radiator, etc.
JOEL KERCHER
07-14-2005 11:36:40
 Re: What is to hot / overheat temp on a 55 to35 in reply to tennesseefarmer, 07-14-2005 11:03:45
DOES THAT MEAN IT SHOULD STAY CLOSE TO THAT NUMBER? HOW MUCH SHOULD IT RISE BEFORE I HAVE TO WORRY?
kyHarold
07-14-2005 11:48:28
 Re: What is to hot / overheat temp on a 55 to35 in reply to JOEL KERCHER, 07-14-2005 11:36:40
I use 205 as a stoping point. I usually never get over 200 but sometimes when I am bush hogging and the radiator gets full of grass mine will heat up. I will stop at 205 and clean out the radiator and let it cool down.
Water boils at 212f (100c for our friends in europe) Al long as your temputer is below 212 then you are still cooling the motor.
doodelbug
07-14-2005 18:21:20
 Re: What is to hot / overheat temp on a 55 to35 in reply to kyHarold, 07-14-2005 11:48:28
water boils at 212 F but dont you use antifreeze it it ? that raises the boiling point!
rtaylor
07-14-2005 19:27:32
 Re: What is to hot / overheat temp on a 55 to35 in reply to doodelbug, 07-14-2005 18:21:20
when we used to race we wanted the motors to get 200 degrees thats where they made the most power. I dont know what a tractor should run at. My F40 runs at about 170 - 180
Lou
07-15-2005 09:10:33
 Re: What is to hot / overheat temp on a 55 to35 in reply to rtaylor, 07-14-2005 19:27:32
I have a MF 50 same problem, radiator and water pump done last winter. Is there a recomended way to flush these engines. Mine is a diesel. Is there a chemical to help flush out rust ect? Thanks Lou
