sickle bar for TO-20?
Grass Roots Far
07-12-2005 16:56:05
Needing to hay a field and only having a TO-20, I was wondering if a sickle bar mower could be attached. I suspect you need an external hydraulic hose to operate the bar up/down movement, and I don"t see anything like that on the tractor. There are, however, 2 ports beneath the seat which can be opened with a large hex tool. Help me understand what I might be able to do. Thanks in advance.
Fred Martin
07-14-2005 03:16:38
 Re: sickle bar for TO-20? in reply to Grass Roots Farmer, 07-12-2005 16:56:05
I had one and they weren"t easy to hook up. Two arms a top link and a break away bar that attaches up under the fender/axle bracket. You could lift it some cause it hung on the lift arms but it seemed to tip the cutter bar down before it came up...and they are run a good bit slower than the rotary type mowers or you could probably make one fly apart.
I wonder if you couldn"t use a "hayside" type rotary mower for mowing hay? Looks like it would be a lot faster and when you unbolt the side of the mower...it kind of winrows it...just don"t know how much it would tear up (and lose)hay. Any comments on someone whose done this? Fred OH
Jeff-oh
07-13-2005 05:09:56
There were sickle bar mowers built for the TO-20 (N series etc.) So the tractor will run them. I do not know if these "origional" mowers had the hydraulic lift feature. The ports you poit out are testing ports for pump pressure. they have also been used to supply external pump pressure. You'll also need to figure out a way to return the fluid to the reseavor. The -ao lift had a replacement inspection cover with a return line conection.
Jeff
steveormary
07-13-2005 09:41:14
 Re: sickle bar for TO-20? in reply to Jeff-oh, 07-13-2005 05:09:56
The sickle bar mowers we used were hiched to the 3pth. The top link had brackets bolted to it and the mower had a chain and clevis. For road travel or travel to the field you would leave the pto shaft not connected,raise the mower and hook the clevis to the top link. When mowing you would let the mower down,the cutter bar down and hook up the pto. You could raise the mower and the cutter bar some with the draft control lever and the sickle running. You do need to slow the engine for this. Also,dont run the engine much over half throttle or you will overspeed the mower and break knives and stuff. You had to raise the cutter bar by hand. There were no hyd.cyl.on this type of mower.
steveormary
Ray,IN
07-13-2005 20:32:22
 Re: sickle bar for TO-20? in reply to steveormary, 07-13-2005 09:41:14
I have a Ford 501 7' sickle bar mower that works fine on my TO30(2HP more). As already stated, engine speed and ground speed must be coordinated to avoid breaking mower parts, and minimize clogging the bar. I would not try to use a hyd mower on these small tractors, it requires too much power.
