Loss of power
Easter Creek
07-12-2005 13:27:38
I have a T0-35 that's been running well up until late. When under load(with a bush hog or using a box blade, or even up a hill) the power drops off a drastic amount. The are new electrics on it(spark plug, wires, etc.) a new fuel filter and air filter. It seems as if the engine is being choked or starved. I'm hoping it's not valve related. Maybe a carb problem. Has anyone heard of or had this issue before. Any suggestions??
Tnaks
Jerry/MT
07-15-2005 17:37:29
 Re: Loss of power in reply to Easter Creek, 07-12-2005 13:27:38
One thing that wasn't mentioned by the others is a manifold leak that will cause air to bypass the carb and result in a lean mixture. Make sure that the carb to manifold joint is not leaking and that the intake manifold doen't have a leak in it. Also make sur ethat you have adequate fuel delivery from your fuel tank to your carb. I believe you have a Marvel-Schebler carb so make sure that the secret filter at the fuel inlet elbow to the carb is clean. remove the bolt/plug from the bottom of the carb and you should have a continuous supply of fuel gushing. if not find out why. If you have a goods supply of fuel, suspect the carb float level or a float valve blockage.
gshadel
07-13-2005 08:32:25
Yes, check timing, you can do that easily with a common 12V timing light, just hook-up the 12V leads to a car battery if you have a 6V system.
Also sounds like a common weak ignition problem. Check your spark, should be nice blue zappy spark. Weak orange spark = lost power.
I know you have new electronics, etc. but I commonly read about new condensers that were bad, points slipping, etc. If your point gap is off by even a few thous., weak spark. Make sure all your connection to the coil and points are clean, clean, clean.
If your timing and spark look good, might be the carb. Run a bunch of carb cleaner thru it, check your "power" mix screw, I think it is the big mixture adjust screw on the TO-35 just like the TO-20. If my recollection is right, they are usually ~1 1/2 turns out, but check your manual for sure on that - 'cus I'm guessing the TO-35 carb is similar to the TO-20 carb.
Matt L
07-12-2005 18:10:32
Id recheck the timing on it - My TO 30 had the same problem when mowing
