Hydraulic problem
Gunnar
06-16-2000 01:52:45
I have a TEF-20 with no working hydraulic. Just the other day when lifting the 3-point, it got stuck in an implement, there was a sharp sound and after that the lift was dead.
The piston is not stuck in any way because the 3-point can easily be liftet or lowered by hand.
Also there is no resistance in the control lever.
Is the safety valve stuck open, or is it something wrong with the control valve, or....?
Thanks for any help!
rod
06-16-2000 03:45:44
 Re: Hydraulic problem in reply to Gunnar, 06-16-2000 01:52:45
Sounds like you may have broken something inside try removing the side covers and see if pump is moving at all inside. look at the small pins on the side of the bracket.
regards
rod
Gunnar
07-20-2000 23:10:21
 Re: Re: Hydraulic problem in reply to rod, 06-16-2000 03:45:44
The hydraulic piston had cracked, that's why!
