What is this tractor
Roughstock
07-08-2005 20:32:30
Looked at a tractor today and since I only have N tractors at this point, I know very little about the TO"S. This tractor had a Transmision that had 4 gears and then had a S on the shifter does this mean anything and does it tell you if it"s a 20, 30, 35? Any help will be appreciated. It had a front bucket on it so the hood was different so the looks don"t help much.
Leroy
07-09-2005 08:25:34
 Re: What is this tractor in reply to Roughstock, 07-08-2005 20:32:30
Would be a 20 or 30 as 35 was 6 speed, 3 and 2 for 6
Gene Stevens
07-08-2005 20:40:09
If you look just behind the stering wheel on the dash there should be a TAG with a SN. That will tell us what you are looking at.
Roughstock
07-08-2005 20:45:29
 Re: What is this tractor in reply to Gene Stevens, 07-08-2005 20:40:09
Does the first numbers in the # tell you or do I have to look it up on something? I think I remember the # starting with 30. Can you tell me what the S on the shift plate is for?
Gene Stevens
07-09-2005 05:14:09
 Re: What is this tractor in reply to Roughstock, 07-08-2005 20:45:29
The SN for a TO 20 would be TO50451 (mine) other TO 20 SN would go as high as 60000. I am not sure of the SN ranges, but they can be found on the left side of the page. The "S" is the starter switch. When you move the shift lever into that slot and push forward (ignition on) it should start if all things are right.
