TO 20 Starter Switch Replace
Gene Stevens
07-08-2005 18:17:17
I replaced the starter switch by removing the two small bolts which held it in place and puting in the new one. Simple enough...well at least that was my thoughts. Looks as if when I try to engage the starter I am not making good contact. The starter (just rebuilt with about 20 hrs of operation) does not wat to fully engage as before. Got out the book and the process for replacement is different. has you removing four bolts and holding the connecting link with a piece of wire and then installing the switch. Then to set the unit the the rear and move forward until you have/make proper contact. Done all of that and still do not get proper contact. I said all that to ask this. It appears the manual picture (pg 97, fig 190)shows a small button sticking up from the ?? which is attached to the connecting rod. If this is true...that may be my problem. If so where can I get a replacement? Or can this be modified? Thanks, Gene
John (UK)
07-11-2005 13:17:20
 Re: TO 20 Starter Switch Replace in reply to Gene Stevens, 07-08-2005 18:17:17
To make sure that it isn't the switch you need to wire a lamp from one terminal to ground (the opposite side to the lead from the battery) so that you know for sure if the switch does make a proper contact. If it does the as has already been said it must be the starter
Jerry/MT
07-08-2005 20:35:58
Gene, When I replaced the starter switch on my TO-30 I had some problems making consistant "contacts" of the starter switch. I loosened the four bolts that hold the starter switch on and moved the switch assembly all the way aft, as I recall. It worked fine after that. You might try to do the same. I didn't need to hold the link with a small wire as the book said.
nonac99
07-08-2005 19:03:32
If you are saying that the starter is spinning but has not engaged the flywheel then in doesn't sound like a starter switch problem. Sounds more like a starter problem.
Gene Stevens
07-08-2005 20:42:22
 Re: TO 20 Starter Switch Replace in reply to nonac99, 07-08-2005 19:03:32
The starter worked fine until I changed a bad switch. I have made several adjustments acording to the book but have not fixed the problem.
