pto shaft seal- spring band in or out?
JayP
07-08-2005 13:03:31
I have a TO30 with the old 1-1/8" pto shaft. I have the shaft pulled and ready to replace the seal. Does the spring band side with the rounded frame install toward the pump or toward the implement side? I've looked through the archives and found some info on the differences between the 1-1/8 and the modern 1-3/8. The local Massey dealer sold me the seal and give a parts breakdown but it does not show which way the seal goes. Also, when I disassembled there was a circlip on the outside next to the threads where the cap screws on. The housing has two circlip channels of which at least one was not being used. The bad seal was a much thicker Chicago Rawhide. The circlips should capture the bearing, correct? Thanks-Jay
Thomas
07-10-2005 05:45:10
 Re: pto shaft seal- spring band in or out? in reply to JayP, 07-08-2005 13:03:31
Seals always go with the "open" side facing the oil. This is because the pressure (in this case just the weight of the oil) causes the seal to tighten onto the shaft so giving a better seal.
JJ2
07-11-2005 05:59:49
 Re: pto shaft seal- spring band in or out? in reply to Thomas, 07-10-2005 05:45:10
What is "open side" for those of us without seal vocabulary? I am assuming this is in agreement with the spring side.
RandyR
07-08-2005 18:12:31
Jay, on my 35 (I'm assuming it's the similar),the seal installs with the circle spring in the seal and the lips facing forward into the differential.
I just replaced mine and had a problem with the lips turning back when pushed onto the shaft, so I used a strip of plastic from a tall ice cream tub, rolled it into a circle, oiled it, shoved it through the seal and onto the shaft, then slid the seal on over the plastic, and then pulled the plastic out. Worked good.
JayP
07-09-2005 04:47:47
 Re: pto shaft seal- spring band in or out? in reply to RandyR, 07-08-2005 18:12:31
Thanks Randy. I was concerned about the lip rolling back. Your method sounds like a good one.
