No oil in rocker arm
Scott Hastie
06-15-2000 01:44:03
Hi there
I have a MF 35 with a front end loader. There is no oil reaching the rocker arm. How can i fix this is?
Thanks Guys
Scott Hastie
Jack in NB
06-18-2000 09:20:36
 Re: No oil in rocker arm in reply to Scott Hastie, 06-15-2000 01:44:03
Hi Scott -
Perkins engine?
Possibly the external oil line feeding the rocker arm, right side from half way up on the block to the rear of the head, has a plug in it, or the compresssion fitting in the line from the "bulkhead" connector through the head to the center of the rocker shaft has a crimp in it. Loosen the fitting on top of the head as the first check for oil flow.
Rocker shaft is adjustable too. Large slot at the front aligns with a punch mark on the mounting bracket at about 30 deg from vertical. Increasing the angle of the slot toward the 90 deg position increases oil flow.
Continental, I can't help you!
Jack
