tiller for te20
jeffheffner
07-07-2005 17:24:22
Can anyone tell me if the pto on my te20 will run a roto-tiller? If so, what size should I get?
Jeff-oh
07-08-2005 05:20:15
 Re: tiller for te20 in reply to jeffheffner, 07-07-2005 17:24:22
This is just to emphasize the subtlety in Marlow's post. The TE-20 has the power to run a roto-tiller. What it does not have is the transmission speed. 1st gear is just too fast of a ground speed to give a tiller time to do it's job. Thus the tines end up just skipping on the top of the ground.
The Sherman transmission was an add-on that provided a hi-low range like later model tractors. So without it you should look at a plow and disk to work the ground.
Hope this helps...
Jeff
TE-20 SN 402##
marlowe
07-07-2005 18:59:55
i have a 5 ft. kingcutter 2 on my to-20 but i have a sherman trans in mine it works great but with out the sherman trans the tractor is to fast in 1st. gear. i have tilled ground that has never been tilled [ deer food plots ] works fine in low low
gshadel
07-08-2005 11:38:22
 Re: tiller for te20 in reply to marlowe, 07-07-2005 18:59:55
Marlowe... I thought the Sherman also reduced the PTO speed in addition to the ground speed. Sounds like that's not a problem with your tiller?
I'd love to be able to run a tiller with my TO.
I almost bought a really rough TO-30 this Spring just so I could pull the Everett Rotovator tranny off of it, then re-sell the '30 and install the Everett on my TO-20. But... the Everett kept kicking out of gear, and the '30 was in really bad shape... so let it go.
Guess I could do the same sort of thing with a N or TO that has a Sherman combo tranny. A working stand-alone combo tranny for <$500 is hard to find these days. But a tractor with a Sherman doesn't sell for much higher than a tractor without a Sherman.
marlowe
07-08-2005 18:03:13
 Re: tiller for te20 in reply to gshadel, 07-08-2005 11:38:22
yes the pto runs slower but it dose NOT bother at all works fine i tilled about 5 acers today that NEVER seen tilling
