haying with a TEA20
holcombwa
07-01-2005 06:27:28
Our tractor for the last 50 years (case VAO) has no clutch all of a sudden so.... The Fergy we got last fall is going to have to do our haying. Have never done anything with it but pulled a trailer. We use a John Deere sicle bar mower and old tedder/rake both of which worked ok with the VAO. My concern is when mowing with the Fergy and the sicle bar gets plugged or overloaded with grass, can you back up and lift the bar with the hoist without the PTO running? Any other tips or suggestions would be appreciated. Thanks,
Stan
LeJo
07-02-2005 04:47:08
 Re: haying with a TEA20 in reply to holcombwa, 07-01-2005 06:27:28
NEVER get off the seat to clean the hay off the bar WITH the power takeoff ON or running.
John (UK)
07-01-2005 13:36:41
The answer is NO you cant back up and lift without the PTO running, what you do is leave the PTO running then back up and lift at the same time (NOT TOO HIGH) and as you reverse and very often the crop will be pulled off the blade without you getting off the seat. As has been said, don't run the PTO too fast, this is one implement that doesn't need PTO speed (545rpm) just run it fast enough to cut at the forward speed you are travelling at and don't try to go too fast forward either, make sure the blades are sharp always, it will cut better and make it easier on the mower and you too.
holcombwa
07-01-2005 22:59:57
 Re: haying with a TEA20 in reply to John (UK), 07-01-2005 13:36:41
I appreciate the responses Always disengaged PTO, backed and lifted with the CASE. Will take some getting used to. Might save a lot of climbing off and on the tractor though cause always cleared the jamb by hand; other wise, it just plugged up again as soon as you restarted. Don't know if I follow with the PTO speed part. Is the PTO speed controlled seperately from the ground speed on a fergy? (the Fergy seems and sounds like a race car compared to the CASE) On the CASE, the mower seemed to cut best at about a walking pace, so that's what we mowed at. Have no idea what that equated to in PTO speed. Will probably try mowing with the Fergy at the same speed and see what happens. Thanks for the input!
Stan
John (UK)
07-02-2005 05:40:09
 Re: haying with a TEA20 in reply to holcombwa, 07-01-2005 22:59:57
You control the PTO speed with the engine speed, then to control the ground speed you select a suitable forward gear, try first gear and see how it goes, if the mower is in good condition it will mow faster than that. To get the cutter-bar clear when it blocks, leave it in gear unless you get off the seat, then reverse slowly with the engine running slow (faster than Idle so it wont stall) don't lift it too soon, allow it to rub on the ground while you reverse, and as you reverse you slowly lift the cutter-bar, doing it this way "WIPES" the crop/blockage off the cutter-bar and it pulls the blockage away from the uncut crop, so you then drive forward and lower the cutter-bar beyond the blockage and away you go, there is often no need to get off the seat. Correct setting of the knife clips and the ledger plates to push the knife forward is essential or it will be like trying to cut cloth with a pair of blunt scissors and you know how difficult that can be. The cut should be clean and not torn out or ripped apart, if it is then you need to look at the setting of the knife on the bar and how sharp it is.
steveormary
07-01-2005 10:14:12
We cut alot of hay with our Fords and Fergusons. Used a Ford 3pth mower. When the sickle bar clogged with hay we would clear the bar with out stopping the knife. Just throttle down to idle and you will be ok. Also watch your engine speed as at not much over 1/2 throttle you will be over speeding the pto. Good luck,have fun and be careful.
steveormary
steveormary
07-02-2005 08:58:09
 Re: haying with a TEA20 in reply to steveormary, 07-01-2005 10:14:12
WE would use 2nd gear on the tractors with 4 spd.trannies and 3rd on the 5 speeds. Just be careful and go easy untill you get things figured out.
Have a Happy and safe 4th and keep us posted on how you do.
steveormary
