Were you mowing with out the cup for the oil bath
Jeff-oh
06-30-2005 06:05:11
A question? Were you mowing with out the cup for the oil bath air cleaner?
Matt L
06-30-2005 07:30:01
 Re: Were you mowing with out the cup for the oil b in reply to Jeff-oh, 06-30-2005 06:05:11
I prolly mowed for 10 min or so w/o it till I noticed it was gone
Jeff-oh
06-30-2005 11:56:47
 Re: Were you mowing with out the cup for the oil b in reply to Matt L, 06-30-2005 07:30:01
I guess that leads to another question. Was the tractor acting up before the cup was gone?
With out the cup the inlet air is not as restricted as with it. More Air... lean mixture hotter fire.
Matt L
06-30-2005 14:28:45
 Re: Were you mowing with out the cup for the oil b in reply to Jeff-oh, 06-30-2005 11:56:47
It was acting up before and after. Im not really worried about trashing the motor since its gonna get rebuilt this winter anyways ( the usual cracked block it suffers from)
Ray,IN
07-01-2005 21:34:45
 Re: Were you mowing with out the cup for the oil b in reply to Matt L, 06-30-2005 14:28:45
It's possible the distributor is worn to the point the timing changed. Try moving the shaft up and down, if there is much movement it need replaced. A lean gas setting on the carburetor power jet will also cause the engine to run hot. This should be set while the engine is under heavy load per owners manual.
John (UK)
07-02-2005 08:50:08
 Re: Were you mowing with out the cup for the oil b in reply to Ray,IN, 07-01-2005 21:34:45
To test the distributor for wear move the shaft side to side as that will alter the points gap, movement up and down is not such a big problem.
Ray,IN`
07-03-2005 19:24:37
 Re: Were you mowing with out the cup for the oil b in reply to John (UK), 07-02-2005 08:50:08
Yes it will John. The helix gears mesh at a specific point, and if the gears, or shaft bushings are worn, the shaft will not run in the right position, changing the engine timing. The sideways movement is easy to spot.
John (UK)
07-04-2005 06:34:11
 Re: Were you mowing with out the cup for the oil b in reply to Ray,IN`, 07-03-2005 19:24:37
Sideways movement is the tricky one and not everyone spots it,(just look back in the archives and see) I agree about the up and down movement but the side movement is the one that causes most trouble and the problem we get here most. You can to some extent take out the wear in the gears by altering the timing but you cant remove the wear in the bearings. You must remember that most of these guys do not have your knowledge about such things and although YOU and I can spot it they are not able to due to lack of experience with the tractor and that is why they come here for help. John
Matt L
07-05-2005 07:47:18
 Re: Were you mowing with out the cup for the oil b in reply to John (UK), 07-04-2005 06:34:11
I got around to messing with the dist this weekend- between all my other projects. Its fine no play or anything unusual. The timing was way off tho - runs a million times better now.
Did find out how light the front end is in 4th gear and giving it gas :D
Now I'm wondering how cracked the block really is from running hot - This winter I'll find out
