to30 manifold glowing red
ric
06-28-2005 19:06:12
hi my dad put a new exhaust manifold on his to30 from valubuit and after a while it glows pretty much red is there something wrong with it or something else
Jerry/MT
06-29-2005 10:53:15
 Re: to30 manifold glowing red in reply to ric, 06-28-2005 19:06:12
As the previous person said, check thetiming. But you may also want to check for an overly lean mixture. Statring point on the mixture adjustment should be 1-1/4 turns out on the power jet screw from full closed. Ferguson's are designed to run a little rich to take advantage of charge cooling due to fuel evaporation.
Matt L
06-28-2005 23:19:55
Sounds like the timing is retarded some - should recheck it
My To30 makes the muffler red if ya work it hard enough then fall on its face after that - looks like im checking the timing this weekend
