Front wheels
Chris Scott - C
06-28-2005 08:53:45
Hi, I'm new to tractors and I have just bought a late 60's 165. I have a number of things to do to bring it up to a showroom standard but first this is my front wheels they are sat a bit like this \/ what would cause this? is it justa case of replacing the front wheel bearings? I get no grinding nois whilst in motion.
gerard
06-30-2005 06:25:28
 Re: Front wheels in reply to Chris Scott - Cork Irelan, 06-28-2005 08:53:45
They should be as a V - ie closer together on the ground that at the top - that way wheel bearing load is reduced and steering easier because pivot point of tyre better matches pivot line of steering shaft.
Ray from Idaho
06-29-2005 12:43:27
I'm a bit confused. are the front wheels supposed to be like /-\ or like \-/ mine look like the inverted v and it seems to steer fine unless I put a heavy load on thr front.
mowr
06-28-2005 10:45:25
What you are showing us is called "camber" and it"s engineered in for easier and better steering. If you jack up the front end and there"s no excessive play in the wheel bearings, be thankful that your spindles aren"t bent so badly that the wheels are now vertical instead of cambered.
