ajustment of the rear wheels on 35
JB Adcock
06-26-2005 17:04:07
I want to slide the rear wheels in on my 35, They have S shaped rails on the inside of the reams. The locks have a 1/2" square head. I assume that you turn these locks and slide the wheels in or out. Is there a trick to this? Do you need a special tool? I tryed to turn the locks but could not get them to move.
Donald Marwitz
06-27-2005 16:16:03
 Re: ajustment of the rear wheels on 35 in reply to JB Adcock, 06-26-2005 17:04:07
Does anyone know where I can get the big rubber seal that goes on the bottom round plate where you change the oil on a Ferg. TO-20? Don
Duner Wi
06-30-2005 19:38:26
 Re: ajustment of the rear wheels on 35 in reply to Donald Marwitz, 06-27-2005 16:16:03
Fergy Part # 1750269M1 from your MF dealer. Cost under $3.00 in 2001.
FergieFlyer
06-27-2005 12:45:17
third party image
Here"s a picture of the wrench Boss Hog was referring to. There are step by step instructions and a picture of the process in the TO-35 owners manual I have. Let me know if you"re interested.
Boss Hog
06-27-2005 09:16:00
I ahve a wrench set made for adjusting the wheels. It looks like a sort of 1/2" breaker bar with an odd looking extension made specifically for this job.
I"ll try to find it and post pics if anyone is interested.
RandyR
06-26-2005 19:39:56
JB I recently had to get new rims for mine due calcium fluid leaking out and causing rust out. There is no special tool to get the locks off. I never did get some of mine off, the threaded pins were rusted in tight and the heads broke off when wrenched. I had to get used ones. New ones are available but my dealer said they were $38 each!!
Used were $10, Canadian bucks.
All you can do is soak them with penetrating oil, Release-all or PB blaster work good, or try heating up the lock with a torch.
If you get them loose, move the inner lock in to the next hole in the ramp, and drive the tractor forward or reverse, which ever you need, to slide the tire in. Then put the outer lock in.
Or you could jack it up, lock the brake, and turn it in by hand.
RandyR
06-26-2005 19:39:36
Lou
06-28-2005 09:08:05
 Re: ajustment of the rear wheels on 35 in reply to RandyR, 06-26-2005 19:39:36
I recently went through what you are. Heat is a no no, there is a socket that fits 1/2 inch square nut. I believe its an 8 point. good luck Lou
