to 30 wontstart
jeff duckett
06-25-2005 15:49:47
put clutchin myto30 when i putitback togetheritwouldnot start anithad gas running out the carb so i put kit in carb but it still wont start any help aprecetd thankyou
danct
06-25-2005 19:59:59
 Re: to 30 wontstart in reply to jeff duckett, 06-25-2005 15:49:47
jeff
make sure you got a good spark if you hold one of your plug leads close to the body of the tractor while cranking, if no spark then work back from the coil to the ignition switch checking to make sure you put everything back properly ,let us know
good luck
Danny
Ray,IN
06-25-2005 21:36:40
 Re: to 30 wontstart in reply to danct, 06-25-2005 19:59:59
Assuming you do in fact have a good spark as Danny outlined, shut off the gas at the sediment bowl, remove spark plugs, and crank the engine a little every few hours to rid the engine of any flooding in the cylinders. When you think all the gas has evaporated from the cylinders,reinstall plugs, use a small amount of starting fluid in the air intake and attempt to start. If it starts you know the carb is the broblem.
jeff duckett
06-26-2005 15:28:47
 Re: to 30 wontstart in reply to Ray,IN, 06-25-2005 21:36:40
ray tryed what you said and it only backfired thanks anyway jeff
Chuck (CA)
06-27-2005 06:31:07
 Re: to 30 wontstart in reply to jeff duckett, 06-26-2005 15:28:47
Hi Jeff,
Backfiring normally is a timing problem, not carb.
Did you take your distributor out somewhere along the line?
jeff duckett
06-27-2005 14:17:27
 Re: to 30 wontstart in reply to Chuck (CA), 06-27-2005 06:31:07
chuck the distributor has knot been outthanks jeff
jeff duckett
06-27-2005 16:38:45
 Re: to 30 wontstart in reply to jeff duckett, 06-27-2005 14:17:27
thank to all who helped was out of time it fried half way betrien no1 an3 got her running at last agian thanks to all jeff
