TEA-20 on again, off again hydraulic pump
Rod in Smiths F
06-17-2005 12:06:43
While adjusting the carburetor today (new manual) I made a number of runs in 4th gear up the long hill near our farm. Then I noticed that the 3 pt. hitch arms were operating, something they haven't done since dropping the cement mixer last summer.
The lift seems quite strong now. What could be wrong with it to cause intermittent failures? Tranny fluid is pretty clear of water, though it may be too modern for the machine. It's **5 instead of **1.
Jim W
06-20-2005 08:05:56
 Re: TEA-20 on again, off again hydraulic pump in reply to Rod in Smiths Falls, ON, , 06-17-2005 12:06:43
Hi Rod,
I had a case where the "control T" on the valve to the pump half popped out of the linkage i.e. one of the ends came out but the other didn't. It then acted the way you are describing, so maybe that's something to look for.
Jim
06-20-2005 15:30:50
 Re: TEA-20 on again, off again hydraulic pump in reply to Jim W, 06-20-2005 08:05:56
Rube Goldberg had nothing on Harry Ferguson...
I've been looking at a parts diagram of the hydraulic pump assembly. The filler plug looks familiar: the whole assembly is upside down in the illustration, right?
Is this "control T" something I can see by looking through the filler hole? Alternatively, is it a "valve chamber clamp" located on the outside of the transmission?
A little advice on which way is up might be appropriate.
Thanks,
Rod
