Hi Everyone;I've needed a pos control for my '54 TO30 for some time. I use the fergie a lot for bushhogging or finish mowing and it was devilishly aggravating having to ride with one hand on the transit all the time. I've read the posts and seen the options for fabricating your own position control. I know it's a simple device, but like many people I have about a 200 hour backlog of day-job work as well as home chores at all times. And occassionally my wife and son like to see me! So in this instance I decided to forego the DIY route and I purchased a Zane Thang. Shipping was quick, it arrived in 2 days. Service and communication was good. The instructions and photos were good but not perfect. Installation was easy. I've used it to cut about 12 acres with a Wallburg 5 foot brush cutter. It worked great for about 5 passes, then I noticed a little more drift up. so I adjusted the device itself and the nut on the friction disc of the transit. it took a little while to get in the zone but I feel comfortable with it now. it's great for setting your bottom height, meaning it will save you from burrying the blades in the ground or having the edges of the bushhog gouge the ground. Once it raises a little high though it doesn't automatically return to the optimum position, so I've been bringing that back into place by hand. I feel the pos control has helped me a lot. I'd estimate it saves about 65 - 70% of the hand adjusting I used to do before installing the pos control. I am hoping that some of you in the forum with more experience with these devices can tell me what I'm doing wrong, or offer some tips to fine tune this device a little more. also, at this early stage of my experince I almost feel like there should be a second "stop" on the pos control to regulate the upwards rise too. That way you could set the lowest and highest settings for your implement, or would that be bad? Rob
