48 te
Sam-Ga
06-13-2005 09:47:59
My 1948 te want stay in 1st gear unless I put just
very little presure on the shifter. What is wrong
with it? THANKS
John(UK)
06-13-2005 14:26:36
 Re: 48 te in reply to Sam-Ga, 06-13-2005 09:47:59
Could be quite a few things. Could be bent or worn selector, incorrect pre-load on the bearings on one of the shafts, wear on the gear teeth on the sliding couplers, the springs on the selector rail plungers weak and require shimming or replacing, or you could be lifting the gear lever when you put it in gear, if you do this you don't push the gear far enough into mesh, if you have been doing this for some time then the gear will be worn and will need replacing.
